Which version of this cooler should i buy for this cpu as the socket is not listed in spec sheets but everyone I've asked said it'll fit anyway.
Intel Core i7-5820K
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16819117402
Noctua NH-D14
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16835608018
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16835608024
Thanks
Get the SE2011 one. It will fit that cpu assuming your using a regular 2011 board.
both coolers are basicly the same.
but with the SE2011 edition, you get the mounting hardware for socket 2011 and 2011-3
So thats the one you should get.
Not sure how high you wanne go on overclocking.
But if you wanne go higher then 4.2ghz, then i might recommend an AIO.
like Corsair H110iGT, NZXT krakan X61, or similar.
Thankyou
4.5ghz should be achievable without much fiddling with the NH-D14. It should stay under 70c
4.5ghz could be done on a good chip.
Mine does hover around 70c on a fat dual 120mm AIO in push pull at just 1.175volts.
Then again I think mine has something fishy going on with the IHS.
