Hello,
do any of you guys have a 200mm fan mounted at top of the Phanteks Enthoo Pro? How did you mount it? Seriously, the mounting holes on top of the case for the fan locations are way too small! Was going to put a 200mm fan (same as the Phanteks 200mm fan that came with the case) there, but will have to drill bigger holes or come up with a clever way to mount it. Just wanted to see what you guys have done before I drilled the holes bigger. That is, IF I decide to drill the holes bigger.
If you have any pics of 200mm fans on top of the Pro, please post them. Would love to see them.
By the way, first post on the forums.
Thanks in advance, guys!
