$2000 Rackmounted Audio PC Build
Hello to the TekSyndicate community.  So happy to finally reach out to ya'll and see whats up.
I hail from Vancouver Island where today we got our first snow of the year.  I've been watching and enjoying the videos you create here.  Thank you for sharing like you do.
I am building a system to be primarily used as a studio/performance pc running Windows and Ableton Live.  The system will need to handle a lot of real-time audio processing(having a ton of audio samples in ram, lots of virtual instruments and virtual effects running, manage many peripheral controllers-usb).  The system will also be used for editing and composing(compression and file conversions, many large audio files layered, multiple monitors).
 I will build it into a 4u rack mount case which will fit into a 8U gator case(http://www.parts-express.com/gator-gr-8l-deluxe-rack-case-8u--262-906).
The $2000 budget is for everything inside the Gator case, but not the Gator case itself.
I need to acquire the hardware only, I will assemble it.
Software, monitors and sound card are on a different budget.
Absolute requirements:
-4u rack mount case(preferably quiet):
-fast ssd primary OS drive:
-support for multiple monitors(4 to start)
Other requirements:
-fast
-lots of ram
-many cores(ableton can utilize a core per audio channel)
Thanks for any help, and please ask and I will clarify anything.
Cheers,
dunkfon
That's a beasty audio editing system you want!
So let's begin:
Processor: I7 4930k - because of its 6 cores and 12 threaths you will have plenty of cores to run your tracks.
Werkgeheugen: 16 GB 1600 Mhz, maybe 32 GB - To store your tracks as you working on them.
Motherboard: ASUS Maximus - just because it's a good motherboard
Storage: Dual 840 EVO 120 GB RAID 0 - because of your speed demants ;)
Storage2: 2x 3 TB WD Black RAID 1 - for a safe place to store your music
Okay, I built the system. It took a while, but I’m happy with it. I couldn’t take much of Gamebases advice due to budget restraints. But thanks for the helping hand anyways!
Here are the specs:
Asus Z87-k
Intel i7-4770 3.40GHz
16GB RAM
Nvidia GTX660
A whole slew of HDDs, 2 mechanical for games and storage, and two SSDs with individual windows installs. One install for the studio environment(no ethernet), and one for games and regular usage
Motu 828mkII firewire sound interface
Rane ME 60 eq
Alesis 3630 compressor
All nice and tidy in a gator rack mount case.
