So my friend is looking to build more of a multimedia pc in his words "a pc that can do anything" his budget is $2000 (holy shit) I know he does alot of thing with photoshop and he will be gaming and he said he would like to have 2 tb of space (not mandatory). One more thing Im not sure if he needs monitors keybords ect.... so maybe a few options would be nice....
Thanks for the help
one build I found was: http://pcpartpicker.com/p/1nwNY let me know if its good or not.
Uh. 2000?
This would be a crazy nice build.
http://pcpartpicker.com/p/1okEU
its just over budget - but this would own!
http://pcpartpicker.com/p/1onKa
http://pcpartpicker.com/p/1oo7F this is alittle bit more but you get 3 ips monitors and two 4gb 760's o also moved to the NZXT 810 its almost the same as the 820 but its better for water cooling and its $100 less
if you can do 8gb ram then http://pcpartpicker.com/p/1oo9q
But its SLI... and drivers are nightmarish
http://pcpartpicker.com/p/1oqvP
hmmmmmm this might be the obe thank you
edited the last build with 3x 22" ips monitors diffrent cass amd mb to get out the door at $1992
http://pcpartpicker.com/p/1ozzA
This would demolish anything: http://pcpartpicker.com/p/1ozIV
