200 Kbps for Livestreams?
Just a really quick question... Is a 200 (up to 700) Kbps (Up) connection good enough for live streams?
I would like to start live streaming but my upload speed is really low, I'm not sure if I would be able to stream in even 480p (at 24/25 frames) with my connection. If I can't go that high, what's the max that I would be able to stream, if at all? Thanks. (Just to add, I'm really doubting being able to livestream with this connection, hence the post)
Also, I had no freaking clue where to put this post so I just put it in INBOX.EXE... Also again, what the hell happened to my formatting on this post...?
No, is the short answer. Nope, is the slightly longer one.
200 Kbps is only a data throughput of 25 KBps which is.....well nothing.
Figured :\ thanks for your reply.
