I'm going to build a high end gaming rig this winter (http://pcpartpicker.com/p/1vRG6) and I'd like some advice on a good gaming moniter that also has good picture quality.
Thanks for the help.
This one is an IPS moniter and will give you the best image and has the some of the lowest input lag and response time of IPS moniters out there so its a good choice if you want the best color and image quality
If you are looking for a straight gaming moniter this is probabaly the way to go with low input lag and response time but you will safrice some color quality and such for a better response time and less blur when moving fast.
Looks like a good monitor but i was also considering this one http://www.newegg.com/Product/Product.aspx?Item=N82E16824236310 any advice?
For gaming I wouldnt go ips because of the response time, I would go with a TN panel.
This broke the bank a little but its 120hz, acer (which in my opinion is a good brand), 3D, and 2ms response time. In my opinion this is a great bang for your buck.
Is there a really big diffrence in color saturation when it comes to TN vs IPS?
well here's the official MLG monitor http://www.amazon.com/gp/product/B007HSKSMI/ref=ox_sc_sfl_title_6?ie=UTF8&psc=1
whats the refresh rate on it?
60hz but its good and a low price :)
