Hi. I have just started to plan a new PC build and was looking for a possessor for about $200.
I'm not sure to go with Amd or Intel, or if I should wait for the new Amd Pile driver CPUs. any help would be great!
I would go with one of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
what parts do you already have, what is your budget for the overall build, you could have too much money invested in one are where you could allocate it to a better CPU or at a cheaper price, do you intend to overclock and what country do you live in so I can give the right links?
Well. Im planning a build for about $1000 or a bit more. and I am going to try to overclock it, but im planning the build from the CPU down. So I don't have a exact parts list yet. I am also from the US
thanks
alright I'll make a list for you with a 220 CPU that can overclock to give you an idea what you're getting, then you can pick out a case and I can adjust it according to your preference and my PC knowlege
ok thanks :)
im bored, ill start putting together wat i would build computer wise with 1000, the price will not include monitors, mice, or keyboards fyi
Well, this is what I would build with $1000:
CPU: Intel Core i5 3570K - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
CPU Cooler: Cooler Master TPC 812 - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176
MOBO: Gigabyte GA-Z77X-UD3H - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128544
RAM: 8GB Kingston HyperX @1600mhz - http://www.newegg.com/Product/Product.aspx?Item=N82E16820104292
GPU: MSI GTX 660 Twin Frozr - http://www.newegg.com/Product/Product.aspx?Item=N82E16814127699
SSD: 64GB ADATA XPG SX900 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820211595
HDD: 1TB Seagate Barracuda - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337
PSU: Enermax NAXN 82+ 650 watt - http://www.newegg.com/Product/Product.aspx?Item=N82E16817194094
Case: NZXT Tempest - http://www.newegg.com/Product/Product.aspx?Item=N82E16811146084
sorry it took so long but I've got one a little better
total=$984.84 shipped
Thanks for all your help. it gave me a good idea of what to look for!
