20 inch or below gaming monitor-144hz quad hd
does anyone know of a gaming monitor, could be a laptop screen by the way, thats at least 1080p, is matte, has good colors, maybe even above 60hz and above 1080p?
Possibly, The same guys that do the DP2Retina display board for the iPad screen also do one for the Screens used in the newer Macs. http://dp2mbpr.rozsnyo.com/ I am using the iPad one and Wendell has talked about it at length before too so that can vouch for the quality. Hope it helps a little.
kind of expensive though, plus how are the response times? also its a bit too small, i was looking at 17 to 20 inches. its for a diy laptop by the way.
