Alright Syndicates I am considering this upgrade 3-way SLI using GTX 580's from my cuurent 2-way GTX580's
So I am running 3 120hz 3D monitors at resolutions of 5760x1080 and am seeing some definate struggle using my current GTX 580 2 way SLI set up.
I have a unique opportunity where my brother will sell me a third card to drop in my rig.
I Currently am running my 2600k set up on a Gygbyte UD7 B3 that will throttle the PCI-e lanes to 8x from 16x.
I have looked everywhere for info on this and have found nothing.
1. what are the pros and cons here?
2. will I get the performance boost i am looking for in games such as high FPS with or without 3D?
forgive me if this has been dicussed before i searched the forums first before i posted and had seen little on this specific topic. also my apologies if this is in the wrong place this question is a little more advanced then a simple GPU question.
and hey!!!!! thanks everyone.
if this little topic see's no activities I will send to the inbox but my money is always on the community you guys are awesome thanks.
cheers
