2 questions!
Hello there,
I have just recently started to casually doing some litecoin mining on my desktop.
But I want to set up my old laptop to mine. It is running linux mint 32 bit, but I can't seem to find a 32bit version of cgminer. Do you guys know where I can find it?
Also how does BTC-E work? Do you get you USD to your paypal? you bank account or what?
Thanks. :-)
When mining, you hook your miner up to a "pool" the pool is responsible for finding blocks you can mine, and to sent them to your wallet. A good pool would something like https://deepbit.net/ they payout fast and have loads of stuff going on in the background to secure your coins. I would still recommend that you withdraw atleast once a week.
Now that you have a pool, its time to find the miner that you are looking for. Miners utilize the CPU or GPU depending on setup, if you choose to do CPU mining its important that its on a 64-bit operating system, else you wont gain much from the 2 or more cores you got. On the link i sent you there is a list of widely used miners you can pick from, as well as a guide for each one. Not sure if any of them are 32-bit tho..
To get them on your paypal:
The tricky part is finding a trustworthy seller, for the most part they don't really use paypal but wire transfers.
Anyway, heres how to do it. Once you mine, you gain coins and they are stored on the pool you sign up on. Once you have enough to fill up the minimum amount you withdraw from the site to your bitcoin wallet. Once they are stored inside your bitcoin wallet on your local computer, you can sent them on to be sold at a market like MtGox.com or my favorite BTC-e.com.
MtGox is very hard to withdraw from, but the price is slightly higher for each bitcoin.
BTC-e have alot of ways to withdraw, but coins are cheaper.
Personally i think the best way is for you to find an exchange like bitcoinnordic.com ( I can vouch for them, sold many bitcoins to them ) they will then exchange them to your paypal, at 9% lower the market price.
I hope that gave you a little more insight in what goes on behind the miners ;)
I have already joined a pool (coinotron), and have 0.12 LTC now :-), but I don't know if there's a better pool. I picked it becuase he's the dude that made the guide I followed. And i know what mining is.
Thank you very much for your reply:-) I will see if I can find a miner :-)
Hmm. I can't seem to find a miner. But I haven't looked that much into it.
Which pool do you guys use, and why?
I'd like to know if I can find a better pool somewhere:-)
Oh, and how worried should I be about my hardware if I were to run it 24/7 at 60 degrees? I have an XFX 7850.
I have quite good airflow in my define mini case. 2 front intake(120mm) 1 bottom intake(120mm), 1 back exhaust(120mm) and 1 top exhuast(140mm).
I don't want to fry anything:-)
