So today I found these earphones : http://m.imgur.com/FIhpmgv
They sound pretty good but I don't want to use them because I don't know how to disinfect/clean them.
So, what are these earphones and how do I disinfect them?
Rubbing alcohol with a cotton swab and rag/towel or something. Wipe the cable using the rag/towel with some rubbing alcohol on it, Use the cotton swab with some rubbing alcohol on it and wipe around the ear piece that sticks out, around the silicone ear piece, and inside the silicone ear piece. Cleaning in-ear headphones are pretty straight forward.
Alright thanks wiemerimer! Hopefully someone knows what earphones/esrbuds those are because I couldn't find out. I don't even know what company is "MP" (on the side of the earbud)
After a quick Google image search of "green earbuds mp", I have come to the conclusion that they are these http://www.muscleandstrength.com/store/sports-fit-ear-buds.html
WOAH you found the exact pair of earphones! I tried Google searching them but I couldn't find them. Thanks Navarre for finding out what they are!
