$2,500 Gaming Machine
I am looking to build my first PC, I've only had consoles so far, I do not plan on editing, and may possibly try overclocking. I have a budget of approx 2,500 a little over is fine. I need everything including a mouse, keyboard, and monitor. Also down the road at some point I would like to get into water cooling.
I prefer Intel and Nvidia, and never have built a computer before. I am willing to wait a month or so for better parts to be available.
  • Budget: $2,500
  • Where do you live (what country),  United States, New Egg
  • Do you need or already have peripherals? Need them all
  • What will you be using your future computer for? Gaming
  • Do you overclock or want to get into overclocking? Possible
  • Do you plan on going for custom watercooling now, or in the future? Most likely
  • OS. Do you need a new one? Yes, Windows 7.
  • What kind of settings do you like or what FPS do you want to play at? The max I can get for the money
  • What resolution will you be playing at? //or would like to play at. 1440p (preferably 120hz), if such monitor is in my price range
what case would you like to have? A NZXT H440 or a Corsair 750D maybe?
Do you want this build to be quiet when you are not gaming?
Do you want SLI or not?
If you were to do water cooling would you do the GPU(s) too?
Would you like to go 2011 for a hexacore or the 4820k or Haswell?
what case would you like to have? A NZXT H440 or a Corsair 750D maybe?  Whichever would be better for what I'm looking for, as in best airflow with plenty of room and easy cable management and runs quietly
Do you want this build to be quiet when you are not gaming? Yes
Do you want SLI or not? I was hoping for at least a single gtx 780, and upgrade to SLI in the future
If you were to do water cooling would you do the GPU(s) too? Yes, and ram, and anything else I can pointlessly watercool just cuz I want to. Though this may be a future expansion.
Would you like to go 2011 for a hexacore or the 4820k or Haswell? Whatever would have the best performance.
I'm not the most technically savvy but will answer all questions the best I can and more I'm unsure of pricing
Now, I haven't played around with such pricey equipment but here is my best shot at helping you with this:
http://pcpartpicker.com/p/2TDPy
This build comes at total of $2365(That is including mail in rebates/promos/etc. and not including tax) You can over clock this right away if you wish too. The 140mm fan is for the from of the case so you can get good air intake and have nice airflow. Hopefully this helps you out and at least gives you a better idea of what you would want. Also, a 1440p monitor costs roughly $350-ish, so I opted for a smaller but a good 1920x1080p monitor from Asus.
i made this sofar: http://pcpartpicker.com/p/2TDUy abit focussed on black/red color scheme
You only have to look at a 1440p monitor that you like, i could not find a 120hz for a reasonable price.
if a 120hz is not available at a reasonable price 60hz will do, also if i would see better performance with 1080p then thats what i will do. I'd prefer 16gb of ram also at 1866 if possible
You need at least a single 1440p monitor with that 780.  Anything less is an absolute waste for a card that powerful. Three 144hz 1080p monitors are also acceptable.
What I'd go for: http://pcpartpicker.com/p/2TMxo
You can bring the price down in a few ways (cheaper case, cheaper monitor, cheaper PSU, downgrade to GTX 780, cheaper cpu, etc.). I included a higher wattage PSU to allow for SLI in the future, as well. 1600MHz vs 1866MHz ram won't make a noticeable difference other than on your wallet (I own two sets in two similar machines, near no difference).  I also included the razer naga mouse, which is one of the best mice I've ever used. Anyone who says otherwise hasn't used one before.
Challenge Accepted. Done and done…here it is!
http://pcpartpicker.com/p/2TVJa
Shaved off a few dollars here and there, making it within budget with a 1440p monitor! BOOM!
(…I love picking out parts, it is so fun!) XD
Why is everyone going for the 4770k for a gaming rig? Get the Xeon or the i5... then shift the extra money elsewhere. Also, https://teksyndicate.com/news/2013/08/15/tek-syndicate-1440p-monitor-club - just get one of the XStars... you can get pixel perfect for just over $300.
As for mouse and keyboard... http://amzn.to/1gys5WM, http://amzn.to/1go1gFN
about the ram no problem, you can grab 2x8GB of the same G.skill  sniper 1866mhz cl9  ram.
Agree about those monitors, the X-star is a very nice 1440P monitor with samsung pls panel, for its price, if you live in the US.
To answer your first question, I personally wanted to max out the budget and work backwards. Unfortunately, I got sidetracked from doing that, so…yeah.
In lue of Logans comment could I see a build as he recommended, thank you. So far I'm liking Rok's the most
Here's mine. Wen't with the Black/Red H440. I went with a single 1440p monitor but its up to you if you want to go triple monitors.
http://pcpartpicker.com/p/2UGfS
I also did up this one as I saw that you may want to venture into custom loop cooling. I picked the Maximus VI Formula because the motherboard itself can be liquid cooled and I thought that might be cool. If you didnt want that you could slide in something like the Gigabyte Z87X - UD4H and chuck a 4770k in there. Whatever floats your boat.
http://pcpartpicker.com/p/2UIA6
From AMD with love:
 Well for all the intel fan boys out there try to do a better build:
http://pcpartpicker.com/p/2VEj2
every single peripheral and even a push pull configuration:
2498.0$
Awesome build, but why not a FX8350 instead? its a bit cheaper, and in therms of gaming performance, they are equal, i have an FX8350 my self and i like it.
Intel: http://pcpartpicker.com/p/2TDUy
AMD: http://pcpartpicker.com/p/2VUkZ
Both thease builds are realy nice, but like Logan also mentioned, on the intel build you could also go cheaper, if you go for an i5-4670K instead of an i7-4770K, since you wanne do overclocking, the Xeon is not option then.
About the monitor grab an X-star with samsung pls panel inside they are great, or a shimian, with LG AH-ips panel.
Grtz Angel ☺
http://pcpartpicker.com/p/2W0e8
edit: accidentally used the reddit markup
