I need help picking parts for a $2,000 gaming. I would prefer to order the parts from newegg and/or amazon. I will be needing a keyboard, mouse, and monitor. I am definitly going to overclock. If water cooling seems reasonable for that price point then I guess Ill go that way. I will probably be mining. I will be gaming at 1080. I will be playing games that are harder to run like Crysis 3 and BF4. I play LoL also but that should be hard to run. I would prefer a either a Cherry MX Brown or Red keyboard. I also would prefer a keyboard with backlit keys. For the mouse I would prefer something that doesn't have 2 buttons on the side but not something with like 8-10. If there aren't any mice that are inbetween I could do fine with somethinng that has just 2. I would prefer a 24" monitor with a low respond time and high refersh rate. Sorry that this post is written weird as I just went down the list and answer every question on the General Guidlines Sticky post.
Ignore a custom loop unless your really into overclocking and you completely understand PC Hardware, if you dont the best option for you is a closed loop CPU cooler.
Custom Loops are the domain of seasoned builders and even then they still mess up sometimes.
Im refering to the point of having to strip GPU's etc for the waterblocks to go on etc, and when i say seasoned i mean people who have been doing builds for a while and want to properly overclock hardware / build something new.
It will be mostly used for gaming. By audio production I just mean't I would prefer an internal/external audio card with good mids and highs, not just lows.
don't expect to get more than 4.2Ghz out of the Heatsink, nor do you need it, stock or 4~4.2Ghz should be fine, I'm sure somebody can suggest a good mech. keyboard under a hundred
look at the IOPS the SSD its slower, and the 780 is faster, yes it does cost more, but you put too much money in unessisary areas, they don't need a sabertooth and a phanteks heatsink is comparative in performance but way cheapercheaper
