I'm just looking for something that sounds okay and doesn't take up too much room on my desk. I might be able to stretch my budget a bit.
Few options for you:
For something that meets your criteria as not taking up much space, and being under $70US and sounds OK (granted, not great or good), the Creative GigaWorks T20's Series II fit the bill (T40's if you can find them on sale).
However what I would recommend doing would be getting some studio monitors. It stretches your budget a bit, takes up a LITTLE bit more room, but they generally have a much cleaner sound, though these smaller 3" drivers ones can sometimes lack in bass. Some options include:
- Monoprice 605300 ($77)
- M-Audio Studiophile AV30's ($90)
- Samson MediaOne 3A's ($100)
- M-Audio Studiophile AV40's ($120)
The last option would be buying a Lempai LP-2020A amp ($20), and some Monoprice 8250's ($30). This stays under the budget, will give you some good decent sounding speakers that can later be upgraded, has the largest driver and possibly the most bass, but obviously takes up the most room. Highs and mids may not be as clean as the studio monitors though.
Honestly, you can not really go wrong with any one of them. I was generally impressed with the T40's, and I own some Monoprice 8251's and really like them for what they are. Just depends on what kind of sound you like, and what kind of solution you are looking for.
Though slightly out of budget, these are on sale: http://www.amazon.co.uk/Edifier-Studio-R1600T-Professional-Speakers/dp/B0038JULWW/ref=sr_1_1?ie=UTF8&qid=1387100891&sr=8-1&keywords=Edifier+R1600T
Here's a review: https://www.youtube.com/watch?v=x-mSeCkMdNs
For that kind of money, I would go with the JBL Creature III speakers. They sound great and are at a farely cheap price point.
Is there something similar to the Lepai LP-2020A amp but with a headphone input as well?
