I plan to buy a 7970 soon, and then buy another one around the end of the year. But I was thinking, should I just buy a 7990 when it comes out instead of two 7970s? I plan to use this with in eyefinity by the way. The only reason I'm considering it is because of course a single GPU works correctly more often than dual GPU.
It's true, and the FPS would be higher with 2x 7970s. So the only pro to using 1x 7990 is the better reliability of a single GPU. So is it really worth it?
