1st Time PC Build, Tips and Tricks
I've been ordering parts to build a new PC, i've never built a PC before. I would like some tips and tricks that you wished you had known when you built your first PC. I also would like to know what can you touch on the PC hardware. I see many youtubers pick up many different components without a second thought, but on the bags the components come in there are several warnings about touching and shocking the hardware. How good are the Intel CPU fans. What are good temps for the Intel i7-4770. Thanks for all the help!
TL:DR Tips for a new builder, especially what should I be careful of touching on the hardware.
These days, components are tough. Dont worry about static, last time this was a concern for me was about '95 - anti static wrist bands were all the rage. Obviously dont go building a pc on carpet and rubbing a woolen sweater across it then go handling things.
4770 with a stock fan will be fine. Temps will be dependent on your ambient temps in the room you are in.
in short - Be more concerned with installing the cpu correctly than that of being overly careful handling stuff and worrying about static.
Thanks for the help!
