Thank you! searching for CRT in about a week (my payday) hehe, will be getting the PC parts tomorrow and the next day so I'm gonna go ahead and build and test with the TV, honestly, i was holding off on purchasing the GPU and the Processor until I heard from you its fine (thought I might as well wait for a monitor) Thanks again!
PSU- Hi Jason thanks for the suggestions! As for the PSU: it is the EVGA 600 B 80 PLUS BRONZE Certified 600W Active PFC ATX12V v2.31/EPS 12V v2.91 3 Year Warranty 100-B1-0600-KR Power Supply (Is this the bad one you were pertaining too?) GPU- The 7970 will give me higher FPS on BF than r9 280x? MOBO-Im currently looking at your suggested MOBO and it looks really good, may i ask some of the prime benefits over the one i listed earlier (not currently fluent in mobo specs etc, hehe)
That's not the EVGA PSU that I was talking about, so you're good there.
The 7970 will perform almost exactly the same as the R9 280x, but it'll be cheaper since it's "older" and second hand. (They're both the same card.)
The motherboard i suggested has a 990fx chipset, instead of a 970. -Probably better VRM design for better overclocking. (I cannot confirm this because I haven't used them personally, but it's pretty much a given.) -Other perks, like 1 more PCI-E slot.
I'm sure someone that's more experienced with recent AMD platforms can tell you more.
still idk what your budget is? But if you could afford a intel haswell i5 with a 1150 mobo, then i would definitely recommend looking into that route. But yeah it all depends on your budget.
Hi, my budget is pretty low, sub 700$. Actually my limit will probably be 700$ since I am going to need an ultra portable laptop (yoga or something of that nature) for my occupation at the moment.
for the price range are the parts sufficient and (makes the most use of the money) or is there cheaper parts that cost the same lol.
Im confused cause theres soon many different kinds of MOBOs / SOOO many features.
What I do know: Mobos need to have same socket type: i.e. 1150 intel or FM2 AMD but thats pretty much it. Is there other things to keep in mind. Seeing that note of yours makes it even worse for me (Some AMD 970 chipset etc.) Since I always thought if its same socket type: done deal, it works together.) But I am so thankful you brought this up, since I probably would run into problems in the future in the same MOBO CPU compatible issues.)
