1st build help
Ok so I'll be going off to college next year and I'm going to need a computer for both gaming and school work. I've never been a pc gamer, so I don't know a whole lot about what goes into the computer itself. Can you help me build a good computer on a 700-1000 dollar budget. Im going to need everything including a screen and all that. I dont know about software? does that come with the parts? Im new to this so Any help will be appreciated.
Watch the videos first, it helps.
this should fit your budget http://pcpartpicker.com/p/qM0E
Here's an amd one. http://pcpartpicker.com/p/qqbT
thank you. I also need a mouse keyboard and screen. Any suggestions?
depends on how much you want to spend.
also everyone likes different kind of switches. shape of mouse etc. so it's hard for us/me to find something that fits exactly you, i could only reccommend what i'd buy
- steelseries 6gv2
- roccat kone+
just add a mouse and a better keyboard http://pcpartpicker.com/p/rBnZ
 Razer products will serve you well
This one will do you good. If you need an OS, your school should be selling flavors for cheap
alright i really like this build and i think im going to go with this one. What kind of software should i get i was thinking windows 7. Do i get a 64 bit or 32 bit?
64 bit. 32 bit doesn't recognize more than 4GB of ram
Read what I just said will ya?
wait so you didnt put a cpu cooler on this one do i need one?
Not unless you really want to OC( even the stock cooler can manage a small OC). If you want one, you can pick up a CM Hyper 212 Evo for $25-$30
Ok thanks you have been extremely helpful. Last question do I need an ssd like those otherpeople's were talking about?
