1st build final? Need CPU Cooler
http://pcpartpicker.com/parts/partlist/
ok i need a cpu cooler for this build. Thank you
What do you want to spend on it?
Linked nothing for me... Coolers:
Cheap: Cooler Master 212
Better Air cooler: Noctua D-14
Single 120 Rad Liquid Cooler: H80i
Better Closed Loop Liquid Cooler: H100i
Best Cooling, Custom water cooling loop (if built properly)
i have a $1000 budget but i can go a little over
Ok, I can't see your build because you posted the wrong link. In the top left of partpicker under System Build is something that says Permalink. Post that URL
If you are looking at air flow coolers, this one works very well and won't break the bank.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103057
Liquid cooling is very nice too.
http://pcpartpicker.com/p/rOk9
Hmmm, isn't that the build I suggested? Well, the best budget cooler out there is the CM Hyper 212 Evo/ +. Next up is the CM TPC 812, which, according to giga, is as good as the more expensive Noctua NH-D14. I won't recommend getting something to expensive though. If you do, you add up the expenses of the CPU and cooler and find out that you could have bought an i5 or something. So a CM 212 or 812 will be what you want. Then OC the chip to get more bang for your buck
Yes it is but I just a few things
