1k-1.1k Gaming/Streaming/Emulating Build (Needs a lookover)
Can't you set up PSX to rely on your GPU instead? I know I did that when I emulated DMC3 and P3 with my shitty 6 year old hardware. I tried to run KH, but I ended up with 35~ frames. I would like the build to be able to emulate perfectly on the side, without compromising too much modern gaming power or budget.
you can make it upscale using GPU power, but there is a lot of complex as hell JIT calculations and the AMD bulldozer Arch is worse at it than the 775 Generation
Huh?
the guy linked to the shopping cart page instead of the perma-link of his shopping cart
http://pcpartpicker.com/user/rescgaming/saved/1uvl
Anymore input? I feel inclined to stick to an AMD based build. Is the motherboard too extensive? I plan to OC but I really don't see SLI in my future. Price-range is 1.1k max now.
http://pcpartpicker.com/p/Uiuz
Looks nice.
650 watt psu
Bump. Will be buying within the next day or so.
