Some more experiments were done in the meantime - setting up an artificially bandwidth limited container on the proxmox host running opnsense to simulate different bandwidth bottlenecks.
The results are included in the following document that I am updating with every new experiment.
I’ll keep updating this thread with new information until I hopefully can resolve the issue at some point. Maybe someone in the future will run into similar issues. Then they can hopefully find this thread and find it helpful.
Switch Upgrade: UniFi Pro HD 24
Oct 11, 2026
UniFi Pro HD 24 fits best
The UniFi Pro HD 24 (USW-Pro-HD-24) covers every requirement in one 1U switch: 3 DAC devices, ~20 copper devices, the modem, the Proxmox host and a 10GbE run to one room.
| Need |
Pro HD 24 provides |
| 3 × 10G DAC devices |
4 × 10/1G SFP+ (1 spare) |
| 10GbE link to a room |
2 × 10/5/2.5/1 GbE RJ45 |
| ~20 clients + modem + Proxmox |
22 × 2.5/1 GbE RJ45 |
| Rack space |
1U |
| Power (max) |
50 W per spec sheet; 60 W per Dateks |
| Price |
~€602 at Dateks (Latvia); check Geizhals for German prices |
It also supports DC power backup via UniFi’s optional backup unit.
The PoE variant (USW-Pro-HD-24-PoE, 600 W budget) lists at €909 net / €1,090.80 incl. VAT. For one access point that isn’t worth it: take the non-PoE model plus a PoE injector.
Other UniFi models don’t fit
Each alternative misses on SFP+ count, 2.5G count or the room link.
| Model |
Ports |
Price |
Why not |
| Pro XG 24 |
16 × 10GbE RJ45, 8 × 2.5GbE, 2 × 25G SFP28 |
$1,243.87 (CDW) |
Mostly power-hungry 10GBASE-T; only 2 SFP28 slots for 3 DAC devices |
| Pro Max 48 |
16 × 2.5GbE, 32 × GbE, 4 × 10G SFP+ |
$649 (US store) |
Twice the ports needed, only 16 at 2.5G, no 10GbE RJ45 |
| Pro Max 24 |
16 × GbE, 8 × 2.5GbE, 2 × SFP+ |
~€441 (Galaxus) |
Only 2 SFP+ slots |
Caveat: UniFi needs a controller
UniFi switches are configured through the UniFi Network application, not a standalone web UI. Without a UniFi gateway, you self-host the controller.
- Run it as an LXC container or Docker container on the Proxmox host, on the management VLAN.
- It only needs to run when you change settings; the switch keeps working without it.
- Define VLANs in UniFi as “VLAN-only” networks, so OPNsense stays the router and DHCP server.
Why the new design should fix the 10G slowdown
The T1700G-28TQ’s small buffer is not the cause: iperf3 through it runs at full speed with zero retransmissions, and no drop counters rise during speedtests. The real cause is any step in the WAN path that is slower than the line (~1,168 Mbit/s), which turns isolated losses at the ISP into costly bursts (see the 10G client investigation below).
The new design removes both such steps:
| Step slower than the line |
Today |
New design |
| FRITZ!Box → switch |
1G |
2.5G |
| Proxmox host → switch (LAN) |
1G NIC |
2.5G trunk |
Every link between the line and a 10G client is then faster than the line, the same situation in which the Proxmox host and the test container reached ~1,050 Mbit/s. Buffer size plays no role here: the Pro HD 24 has 2 MB vs the T1700G’s 1.5 MB, a negligible difference.
10G link to a room
Use one of the switch’s 10GbE RJ45 ports over copper, or the spare SFP+ slot over fibre.
| Option |
Reach |
Trade-off |
| Cat6a, 10GBASE-T |
up to 100 m |
Power-hungry at both ends |
| Cat6, 10GBASE-T |
typically ~55 m |
Often enough in a house; same power cost |
| Fibre, SFP+ |
far beyond house scale |
Lower power; needs a fibre run and uses the spare SFP+ slot |
Current and proposed setup
[embedded content: current setup · WAN and LAN on separate NICs, both at 1G]
Today the modem and the host’s 2.5G NIC both negotiate 1G on the old switch, so WAN is capped at 1G.
[embedded content: proposed setup · 2.5G trunk for WAN + LAN, 1G for management]
In the proposed setup, WAN (VLAN 10) and all LAN VLANs share the 2.5G trunk, and Proxmox stays reachable over the 1G management NIC even if OPNsense is down.
WAN line: FRITZ!Box 7632 on G.fast
The line delivers about 1,090 Mbit/s of usable download, so today’s 1G link to the FRITZ!Box caps it at 930. The 2.5G link removes that cap.
The ISP’s wall port connects to the FRITZ!Box’s DSL port. That’s G.fast over the building’s telephone copper (FTTB), not Ethernet. The FRITZ!Box terminates DSL and bridges PPPoE onto its 2.5G WAN/LAN combo port, where OPNsense dials the session. The 7632 supports G.fast up to 1 Gbit/s; its 212 MHz profile gives about 1 Gbit/s each way.
| Line value (FRITZ!Box) |
Download |
Upload |
| Provider profile cap (DSLAM max.) |
1,168 Mbit/s |
292 Mbit/s |
| Line capacity |
1,337 Mbit/s |
325 Mbit/s |
| Current sync rate |
1,168 Mbit/s |
292 Mbit/s |
| Measured today |
930 Mbit/s (1G port limit) |
275 Mbit/s (line limit) |
| Expected with 2.5G link |
~1,090 Mbit/s (line limit) |
275 Mbit/s, unchanged |
The line syncs at the provider’s cap with headroom to spare, so it should be stable. Usable throughput is about 6–7% below sync because of line encoding and Ethernet, PPPoE, IP and TCP headers.
Next steps:
- Make sure the FRITZ!Box combo port runs in LAN mode and links at 2.5G to the new switch.
- Set the OPNsense FQ-CoDel upload pipe to ~250–260 Mbit/s (90–95% of 275).
- After the switch upgrade, measure download with the shaper off, then set the pipe to 90–95% of it (expect ~1,000–1,040 Mbit/s).
- Confirm with a bufferbloat test under load; if PPPoE stalls below line rate, check single-core load on OPNsense.
10G clients download slower because a step slower than the line (1G) in their path turns isolated packet losses at the ISP into bursts. A 2.5G step does not, so the upgrade should largely fix it. One part, the 10G NIC’s extra sensitivity to these bursts, is not yet explained.
The symptom
On the same Windows host, same speedtest server: the onboard 1G NIC reached 925 Mbit/s, the 10G SFP+ NIC only ~775–850 Mbit/s. The same happened on Ubuntu, on two switch ports and with three different 10G NICs.
What was ruled out
| Suspect |
Test |
Result |
| Switch buffer (T1700G-28TQ) |
iperf3 OPNsense ↔ 10G client, both directions |
937–944 Mbit/s, 0 retransmissions |
| Drops inside the network |
Counters on Proxmox NIC, its queue, OPNsense interfaces |
0 drops during tests |
| Receive window size |
Windows autotuning restricted |
799 Mbit/s, startup loss only slightly smaller |
| Too few ACKs (stretch ACKs) |
RSC off; interrupt moderation off |
Worse (736 Mbit/s); the 1G NIC actually ACKs less often |
| FRITZ!Box 1G port |
FRITZ!Box cabled directly to the host’s 2.5G NIC |
10G client still 775 Mbit/s |
All packet loss happens upstream at the ISP, which is normal when a G.fast line runs at full speed.
Key finding: loss pattern, not loss amount
Same server (37.51.193.149), FRITZ!Box on the 2.5G direct link, captures on the OPNsense WAN interface:
| Client |
Speed |
Retrans. % |
Packets per gap |
| Proxmox host (no step) |
1,058 Mbit/s |
~6.2% |
~1.2 |
| Windows, 10G NIC (behind 1G step) |
775 Mbit/s |
~5.3% |
~6.6 |
The host lost slightly more packets but was 37% faster. Its losses are isolated single packets, which TCP repairs cheaply. The 10G client loses runs of ~6–7 consecutive packets, which force the server to slow down much harder.
Controlled experiment: artificial step in front of a container
An LXC container on the LAN bridge, with an htb + fq_codel limit on its veth interface to simulate a step, same server:
| Run |
Speed |
Retrans. % |
Packets per gap |
Drops at step |
| A: no step |
1,036 Mbit/s |
6.4% |
1.4 |
| B: 1G step |
911 Mbit/s |
4.3% |
4.7 |
3 |
| C: 2.5G step |
1,056 Mbit/s |
6.7% |
1.2 |
0 |
Conclusions
- Proven: a step slower than the line turns isolated ISP losses into bursts (B vs A), even without any 10G NIC.
- Proven: a 2.5G step behaves exactly like no step (C vs A), because it is faster than the line. This is the 10G clients’ situation after the upgrade.
- Unexplained: behind the same 1G step, the container reached 97% of the 1G maximum, the 10G client only 83%, with longer loss runs (6.6 vs 4.7). The 10G NIC’s receive path handles the bursts worse; earlier tests point to its ACK behaviour, but the mechanism isn’t pinned down.
- Hypothesis: the local queue at the step absorbs excess data without dropping, so TCP builds up more data in flight and overshoots the ISP’s queue by more at once.
Verification after the upgrade
- Run the 10G client against 37.51.193.149 with a WAN capture.
- Success looks like ~1,050 Mbit/s with ~1–1.5 packets per gap.
- Keep container 900 for comparison runs; remove the limit with
tc qdisc del dev veth900i0 root.
Recommendation
Buy the UniFi Pro HD 24 (non-PoE) plus a PoE injector for the access point, provided you’re fine self-hosting the UniFi controller. If you’d rather avoid a controller, the MikroTik CRS326-4C+20G+2Q+RM remains the alternative (20 × 2.5G, 4 combo SFP+/2.5G, 2 × QSFP+, RouterOS).
