So, I want this build to last me 4 years of high settings, and fps. Of corse, I'll have to upgrade if I want to maintain this, so I plan to add a second GPU for two-way SLI. Once I have this I will pick up two more monitors for nvidia surround ( 3 monitors, all 1920x1080). That's the plan, anyways. I have posted similar threads in the past reguarding this build, but I am here for some final thoughts on this build before I pull the trigger.
What do you think?
Is it all compatible?
Is anything bottlenecked?
Let me know, I appreciate any thoughts, suggestions, or tips. Thank you.
Everything seems fine to me. You should be able to run three monitors off a single card, by the way. My 650 can power three monitors simultaneously, so I don't see why you'd have any problem with three.
Can your 650 run high settings and high framerate at 3 monitors? I've always been told that one 680 would not be able to power 3 monitors well. I dunno, I guess I'll figure it out as I go. :P Thanks dude.
Sounds like a sick white beast to me, but be mindful of that triple slot 680...overtime it might sag on the PCI slot because its so massive and heavy, Buy like a pole or a stand to support the hanging end of that card
I've seen some pics of that 3 slot 680 slanted on the mobo and it really breaks my heart :c
Actually, the GPU is a two slot 4GB version. ASUS released a more compact version with more VRAM. Here's a link to it http://www.newegg.com/Product/Product.aspx?Item=N82E16814121705
