I've been a lurker for a while, but decided to create an account and submit my build log from mid August after the Inbox.exe 0040 episode. I'm a big gamer, so this isn't necessarily a 'kill my console' PC as I own just about every console since the SNES days. That being said, I've moved over to gaming on my PC more predominantly in the last 5 or 6 years or so.
My goals for this build were:
1) Performance (on a budget). I tried to go for components that were a good bang for the buck at the time of purchase. Sure a Titan has performance, but the performance:price ratio was extravagant so I wouldn't consider that a high-value component.
2) Silence. I've always found the high-pitched wines and whoosh of low quality fans or components terribly annoying. I wanted to make a beefy gaming rig that didn't sound like a jet on my desk. Hence the Noctua fans and 6-fan controller.
3) Darkness. Don't get me wrong, LED lit water-cooled machines are fun to look at. I love the craftsmanship to them especially, and how drastically different custom PCs can look due to the style of the owner. BUT- I don't want that lighthouse in my bedroom polluting my darkness; I'm weird like that. I even left the HDD and Power LED leads unplugged so that there is zero light emitted from my PC when it's powered on.
4) Style and Functionality. This will, of course, be a very subjective part. For me, I picked a Fractal Design Arc Midi R2. I think the case is sexy as hell and very functional. Things I cared about: ability to mount 140mm fans, easily accessible fan filters for all fans, and USB 3.0 on the front panel. It's got filtered mounts for 7 fans total and is sexy as hell to my eye.
My build pics are here http://imgur.com/a/VYGW2#0
Specs:
- i5 4570 Haswell
- GTX 770
- 8 GB DDR3 1600
- MSI Z87 G45 Motherboard
- Corsair HX 750 PSU
- 120 GB SSD for OS
- 2TB Storage / 2 TB Backup
- Noctua NH-D14 CPU Cooler
- NZXT Sentry Mix 2 Fan Controller
- 5 140mm Noctua fans for oh-so-quiet cooling
Points of note:
- I'm by no means a professional PC builder, I've only built 4 or 5 PCs in my day. Very light modding only on this build.
- I've also never delved into overclocking. I went back and fourth on getting an unlocked CPU, but decided on a non-k sku i5 haswell that was on sale for a great deal.
- My photo log is technically unfinished. I could add photos of my complete setup, and the case open and running with all components installed.
- I also haven't setup GPU Boots 2.0 yet, nor done any true benchmarks on any of my games.
* Update: I've added some completed build photos, as well as a few benchmarks.
