$1700 Australian Build - Thoughts Required
Here is my idea for a $1700 Australian build.
I wanted to know if anyone had any suggestions or improvements or if there are any issues such as overheating/not fitting in the case.
http://pcpartpicker.com/au/p/uN6z
Thanks a lot!
That my friend is a build for a man to be jealous of! Nice work! However for the money could you not afford the 690?
Looks good, alot of room for upgrades and very solid. My only change would be to move to Windows professional incase you want to install more RAM.
That is a monster of a system, is it a video editing rig as well? Have you looked at the 3770k, it may be a $20 more then the 3770 and it might be good for you to be able to OC later on. It would be terrible to spend that kind of money and not have the option.
