Hi guys once again... Which GPU?
i have had a look at the fancy GTX 660 at £160 from Novatech
what is an equivalent GPU in terms of perfomance? and can i get it ffor under £170
I have looked at radeon HD7870,HD7850 etc. but still unsure on amd
i had a 650 that was damaged in delivery (it was ok i guess-it played minecraft)
what can i get?
if your stuck i live in the uk and regualrly look on HUKD(hotukdeals) http://www.hotukdeals.com/ you can find some good deals for me/yourself if you know what gpu number is
Uhm, if you live in the UK you're best off with Amazon. They sell almost every graphics card and usually for quite cheap. This 7870 looks decent but if I were you I'd look for yourself. If you are on a budget like that it's advised that you go with AMD as they generally offer the best bang for your buck.
http://www.amazon.co.uk/Asus-7870-Radeon-DirectCU-Graphics/dp/B008A1C252/ref=sr_1_2?s=computers&ie=UTF8&qid=1360441064&sr=1-2#productDetails
I'd reccommend a 7870 ghz edition from HIS, for overclocking. Don't live in europe and converting euro to nz to us is a bit of a hassle lol. But i'm pretty sure it's under 200 at least.
