I need a 17" laptop, my budget is about $600, don’t mind buying used. I need 8GB of RAM, and a good keyboard, 4 cores would be nice but not a necessity, just need it to be fast enough that it’s not annyoing. beyond that I don’t really care about anything else.
thanks.
also, have you ever used the lenovo? if so, how was the keyboard?
I recommend Dell
Also all the components are replaceable. Battery, RAM, SSD, and Wi-Fi Card. 17 inches are hard to come by since the rise of Utlrabooks.. most 17 inch laptops have moved into Desktop replacement territory so it's going to be hard to find a cheap good one. but this is my recommendation. I've had good experiences with Dell.
though that CPU is a dual-core sadly but Hyperthreaded cores.
