$1600 Build
While i wait for my pre-paid cards to get fixed i thought i might as well see how i can improve my build.If i can improve it i think i have made a pretty solid build.
Heres the build http://pcpartpicker.com/p/1BboM
Everything seems fine , the only thing is the cpu cooler I would shop around for better ones (more mass index)
Whats wrong with the 212 Evo? I heard and have seen that its pretty good, that's why i chose it.
The 212 is a budged option, if you want to oc the 8350 to the max get a dual tower cooler or a dual rad water cooler (its fine if you dont oc or aiming a fair bit under 5 ghz). Other then that 8 gb ram would be more than enough if youre just gaming. I also wouldnt get the 770 because its totally overpriced, It performs pretty much like a 670/680 or a 7950/7970 but costs twice as much as a 7950. A 128 or 256 gb ssd for the os, applications and some games is almost a must for such a budged.
Yeah im not going to overclock i just don't see the point unlike some people think its pointless to not overclock but oh well. I know i probably don't need 16gb of ram im just getting it because i can, im going to start video editing and stuff but it wont be heavy editing. SSD's from what ive seen are pretty amazing but i just don't see the point in getting one, i don't care about my os taking 20 seconds more i wont be in a hurry ever to turn on my computer and load it up. Sure if i had a gun to my head and they said you gotta load up windows in 10 seconds i would be fucked but that will never happen.
I would still consider just getting an SSD over 16GB of RAM, also change out that overpriced 770 for a 7970, even top of the line ones like these are cheaper.
http://pcpartpicker.com/part/msi-video-card-r7970tf3gd5ocbe (I'm assuming this is the Twin Frozr model)
http://pcpartpicker.com/part/asus-video-card-hd7970dc23gd5
http://pcpartpicker.com/p/1BeAq i fixed it :D
