$1500 Gaming PC Help
Hello everyone!
I'm looking to build a ~$1500 (USD) PC for gaming. I plan on doing a little overclocking, not too much. I also need dual monitors. This is my first build, but I think I have a good idea of what I need for the most part. My knowledge gap mainly surrounds the motherboard.
Here's the parts I plan on getting: http://pcpartpicker.com/user/raelcun/saved/38LZ
I've already purchased the CPU, Memory, Case, Power Supply, and Monitor. I'm looking to spend roughly $700 for the remaining parts, but if there is a reason to spend a little extra ($100 or so), that's fine as well.
I've been told not to skimp on the motherboard so you can expand your computer in the future. I've been looking at these motherboards, but I'm lost as to what the meaningful differences are and have no experience with their reliability.
MSI Z87 MPower MAX, ASUS Maximus IV Hero, ASROCK Z87 Extreme4
I'm also not sure if it's worth the extra money for a sound card or wifi adapter when the motherboard may have those built in. I don't know what type of CPU cooler would fit my needs either or how much I should spend on one. I have a 120GB Kingston HyperX SSD in my laptop and I love it. I'll probably stick that in my new desktop.
General knowledge and guidelines for my first pc build are very welcome!
There is very little point in buying overly expensive overclocking haswell motherboards. Most midrange z87 boards will reach the very same overclock as their expensive bigger brothers. eg - Gigabyte GA-Z87MX-D3H so forth. Its only worth buying an overclocking rich haswell motherboard if you are a) uber rich and dgaf b) bragging rights c) want to have exotic cooling for nice oc's.  You are already looking at buying a sound card, therefore making little use of the better onboard sound provided by a higher end motherboard. Quality wise, its always down to the silicon lottery. High end, mid range, low end all can fail at any moment. Board with better caps and stronger mosfets have higher durability but are still prone to the odd failure.
Money is best spent on better cooling so you can have a little more fun overclocking - noctua u14s or h100i for example. The 212 will really struggle even with a small oc.
The 212 will not struggle, it can easily reach 4.4 ghz which is all you're going to get with a mid-range mobo.
I would go for something like an 280x and an ssd
Alright, I'll get a Noctua U14S; they have really good reviews. As far as motherboards go, do you have any recommendations for a build with a 770 or a 280x?
Take a look at the MSI Z87-GD65 Gaming
