Hey guys, I plan on building my first computer this summer and I plan on wanting a budget of around 1500 dollars. I'm really new to this so I might be asking a stupid question but what kind of performance could I expect from a build that cost around 1500? Such as being able to run games, etc. It's basically going to be only for gaming and possibly streaming, as well as normal everyday school tasks such as word, etc.
Also if anyone would like to take the time to create a couple of builds for me that would be greatly appreciated so I could start looking at some options. Thanks guys and I really appreciate any help!
should be fine, i think that's the more high end price range as long as you're not into watercooling n stuff and and budget emphasis to maximize your gpu choice.
Thank you so much for this, you even chose the case that I planned on using haha. I should be able to run basically every game with this build correct?
Also, why go AMD over Intel? I'm assuming because since I'm only going to be gaming really that the AMD multithreading will help me in future games? I'm quite new to this whole building a computer thing, so I'm just trying to learn. I appreciate the help!
Well, the FX-8350 is a beast for streaming, compared to the i5. It's also cheaper which allows for a better GPU.
The 8 cores of the FX-8350 will also help with future games, as console ports will likely be able to use up to 8 cores and the 8350 should perform around or a bit better than the i5.
