144Hz cable?
I bought the asus vg248qe, but i read online that the hdmi will not work for 120/144Hz, is true?
Can I use the HDMI or I really need to buy the dvi-d dual link? and if I need to is this ok? http://www.amazon.it/Belkin-F2E4141cp3M-DD-DVI-D-Dual-Link-Cable/dp/B004PY4YCM/ref=sr_1_13?ie=UTF8&qid=1392126993&sr=8-13&keywords=Dual+Link+DVI-D (if links are not allowed I'll remove it).
I have a 7970 (sapphire dual-x).
Thanks
it is true and it will not work.
now only dual-link dvi will save your butt.
end of the story.
hdmi is for shytbaggs... get a d.v.i. dvi is ur friend
i also bought it and got it this week. the dvi cable that comes with it will work for 144 hz
