1440p with 7870
So i want to get into the 1440p club but i am not sure if my 7870 can run games at that resolution. I use an 1080p monitor right now
I do plan to invest in a beefier card (like an R9 280X or GTX 770) anyway. So would it be wiser to invest in the card first and then the screen or the screen first followed by the card?
It will take a few month to save up for either after i have made my first investment.
I would probably go for the screen first.  If you get the card first if it takes a bit to save up it might be a little dated by the time you get the screen.  Just lower the quality a bit for the higher res
Agree with ragingh4vok.  It'd be best to get the new screen first, because you'll be able to play games that your 7870 can handle at 1440p, and anything it can't handle you can just turn down to 1080p.  Get the video card later when you have the money, so you can get the most up-to-date card available at the time.
I'd think the 7870 can easily handle 1440p on most games. My 560ti can play games like Chivalry on high, BF4 beta on low/med.
You'll be able to play games. Invest in the screen first.
Thanks for the answers. i was leaning towards buying screen first because when doing homework it would be nice with a bigger screen. But i was still a bit unsure.
Though i doubt that any new card is gonna come out in the time frame that i am saving up in, i do suppose that Nvidia could introduce maybe a 760ti that would hit an even better sweetspot.
So 1440p here i come :P
