1440p Monitor Suggestions; 2560x1600 worth it?
Hello Logan and Wendell (and possibly Qain),
I am going to be building this PC pretty soon...http://pcpartpicker.com/p/1RqOd
It is going to be used mainly for gaming, but also for some light video editing and After Effects work.  My question is this; I am looking for a 1440p monitor and I have no idea which one to go with.  I have been leaning really closely towards the X-Star, but I have also been recommended the Shimian and Qnix.  I was also wondering if I should save up the money and go for an Asus or Samsung.  Any advice would be appreciated.
P.S.  Do you think investing the money in a 2560x1600 monitor is worth it?
Thanks in advance!
hi,
if you dont care about usb ports and such just monitor go for ASUS PB278Q 27-Inch... which sells for $550
if you want to have 2 extra usb 2.0 slots go for Dell U2713HM-IPS-LED CVN85 27-Inch which sells for $630
edit the asus monitor has better ms also which will be better for gaming
and dont buy dell ultrasharp U2713H 104P6 27 inch they have bad rating and many isssues not worth the 2 usb 3.0 slots
Have no fear, I will never buy a Dell product.  The quality and customer service has gone down the toilet in recent years.
I agree, I would never buy Dell products. I grabbed the PB278Q, and it is an awesome monitor. Absolutely nothing wrong with it. It's worth the premium over the Korean panels.
Does it have an audio out jack on it?
Yes.
Move to other-hardware, this isn't a Inbox question.
The short answer is no.
Unless you have money to burn, investing in a 2560x1600 monitor is a complete waste.
I personally own the Dell 27" U2713HM UltraSharp 2560x1440 monitor, and it is absolutely fantastic.  I had the opportunity to put the Dell 30" U3014 UltraSharp 2560x1600 side-by-side at my Micro Center, and I can tell you right now that you won't miss the extra space.  Yes, the 2560x1600 monitor was very sexy, and I could've bought it, but for the extra price you pay, it's just not worth it.
As an aside, I purchased the ASUS 27" PB278Q 2560x1440 monitor before I ended up sticking with the Dell to see which one was better.  I honestly couldn't tell the difference.  The deciding factor for me ending up being price.  At the time, I bought the Dell for about $585 while the ASUS was going for about $630-$650ish.
Dell has some very nice IPS monitors out on the market right now, and I would gladly recommend them to those looking to buy one.  They have a bad reputation for the other hardware they sell (computers, mostly), but it's really hard to bash the quality of their monitors.
I can't speak for owning a Dell screen but the ones ive seen have been pretty nice. The only Dell product i would even consider buying would be a screen, avoid everything else like the plague tho.
lol this is my dell monitor but the more expensive line alienware .. hahahhaha funny pic, just kidding but seriously i had to live with those 2 lines for a while lol.. i hope u add this on your videos for the lols xd
http://i.imgur.com/iYnFch6.jpg
only worth it if you need a large workspace area. 1440p will give you much larger area for windows annd such if you are doing any kind of edditing or digital creation. if you dont plan on doing any of that stick to 1080p and save the cash.
