1440p monitor, linux issue
Hello!!
I have a resolution problem with my monitor. I have an inspiron laptop with HDMI output capable of 4096x2304 24Hz output and I connected to it a 1440p 75Hz monitor. While booting in windows 1440p 75Hz works fine, in linux(mint) max resolution is 2048x1152 60Hz. I tried other linux distros but no luck.
Thank you in advance
Please list hardware specifications. Not enough information to work with.
What distro are you using and what DE are you using. Are you Using Wayland or Xorg?
In windows set the refresh rate it to 75Hz, then check in the options of the monitor if the panel actually runs at 60Hz.
