So I'm looking for 140mm fans to put on my H110 that I just bought. From what I have seen the best way to go in terms of fans would be high static pressure ones like the Corsair SPs or the Noctua NF-P14 FLX. The problem with the Corsair SP series is that they only come in 120mm form factors and the AF series are better for case airflow. The problems with the Noctua is the price(which I can look over if it's worth it and the only one) and the color, though they will be in the front of my case and I will never see them through the window.
My question is, are there any good alternatives to these two fans, if not I will go pick up one Noctua tomorrow to switch and temporarily use the R4 stock 140mm next to it until I buy another Noctua or they release a 140mm flavor SP series fan, etc.
Thanks!
-Jetix
