$1400 pc build your thoughts
this is it:
http://pcpartpicker.com/p/1jfOD
im going with a Corsair Carbide Series 330r case
should i go with a single gtx770 or a 2 way sli of something else?
I'll post a more "effecient" build, this is for gaming correct?
and I would really suggest a 200R or a 300R since the 330R's cooling is absolutly horrid
Get a 3xxx series CPU if you are going for a Z77 board.
This is what I would get http://pcpartpicker.com/user/Killerfrenzy96/saved/20d4. The Arc Midi 2 is a really good case.
an amd option
Intel option
Closed loop water cooling is overrated, this is cheaper and cooler than a H100
http://pcpartpicker.com/p/1iVL4
How about a 780?
missing a case, third party heatsink and SSD but only two of those is optional
http://pcpartpicker.com/p/1iW1B
updated the build... still havent decided on a case
the phanteks heatsink will perform better than that closed loop water cooler
If you don't get the watercooling get this http://us.ncix.com/products/?usaffiliateid=1000031504&sku=47090&vpn=NH-D14&manufacture=Noctua&promoid=1413.
^also a great HeatSink
ok
updated
This is what my friend and I are building the this coming weekend once NCIX ships >_>
http://pcpartpicker.com/user/njm1112/saved/1S9M
i think im going to do an amd build tomarrow
I would recommend a SLi 650Ti which are about equal to a 680. And your motherboard, change it to a Z87 which is more compatible with the i5 4670k.
it is a z87
Why?
SLI offers more heat output, more power consumption, takes up Space and potentially micro-stuttering. That and it doesn't offer as much upgradability.
Single gpus are usually the way to go.
ok ty
