Build Here : http://pcpartpicker.com/p/1904E
I just need opinions and any suggestions anyone has.
Later i will add; SSD,8gb more ram, possibly upgrade to GTX 770 and another monitor for dual monitors.
http://pcpartpicker.com/p/192qN
This is the best i could do. You don't need that many case fans, but i added some since it seems like you wanted them there :P
Now with this build you get water cooling + a much better GPU.
The Noctua NF-F12 i added for you to use with the H60i, i use the two together myself, and it runs perfectly.
I also swiched the memory with the Crucial Ballistix sport, because that RAM is cheaper than most other, while it still is very good quality RAM (I use 16 gigs of it in my build, so i speak from experience).
I would also recommend investing in a mechanical keyboard if you have the money for it. It is so much more comfterable to type with than a normal membrane one. :D
