$1400 Gaming Build
Please move down to the 5th post to see the build I have planned.
This looks really beastly for the price. I think that cpu might not be a true 8-core processor though, if I remember correctly. I think it was a quad-core with 4 extra virtual cores. But for the price, even if it's not 8 physical cores, I bet it will work decently for multi-threaded stuff.
Not much reason to get an AMD CPU
a 390X isn't really going to be worth it over a 390, and also you'd want the DEVIL 390X as it's just about the best 390X around
aside from that why aren't ya getting a free-sync display? it hardly costs any more than that one
and the HR-22 is going to be the fanless cooler to get, has 2 more heat pipes compared to that one
PCPartPicker part list: http://pcpartpicker.com/p/zqMxD3
Price breakdown by merchant: http://pcpartpicker.com/p/zqMxD3/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor ($327.99 @ B&H)
CPU Cooler: Thermalright HR-22 Fanless CPU Cooler ($86.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-S2HP Micro ATX LGA1151 Motherboard ($71.38 @ Newegg)
Memory: G.Skill Ripjaws 4 series 16GB (2 x 8GB) DDR4-2133 Memory ($61.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.24 @ Directron)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card ($309.99 @ SuperBiiz)
Power Supply: XFX 750W 80+ Bronze Certified ATX Power Supply ($78.99 @ SuperBiiz)
Monitor: AOC G2460PF 144Hz 24.0" Monitor ($261.98 @ Newegg)
Total: $1248.55
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-03-22 21:40 EDT-0400
I would go with something like this
http://pcpartpicker.com/p/K3T7cf
Very decent and well balanced gaming setup for the money.
I also made a Haswell version which is slightly cheaper.
http://pcpartpicker.com/p/qF2LvK
Of course you can also go cheaper if you like.
Alright I updated some specs on the build. Important notes to consider with the build though.
  1. I dont overclock CPU's, so no unlocked CPU's or aftermarket cooler.
  2. For now I prefer HDD instead of SSD.
  3. I prefer Micro ATX saves room on the desk.
Now some of the parts in the build aren't all on PCPartPicker, so will just type them and give links to them. :D
Intel i5-6500 Quad-Core 3.2GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117563
G.Skill NT 8GB (2 x 4GB) DDR4 2133
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231958
GIGABYTE GA-B150M-D3H (Rev. 1.0)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128874
PowerColor DEVIL Radeon R9 390X 8GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131676
EVGA 750W 80 PLUS Bronze Modular
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438025
Fractal Design Mini Black Micro ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352011
WD Blue 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
AOC G2360PF 24" 144hz 1ms Free-Sync 1080p Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824160273
CM Storm Devastator Red LED
http://www.newegg.com/Product/Product.aspx?Item=N82E16823129032
XTRAC PADS Ripper Mouse Pad
http://www.newegg.com/Product/Product.aspx?Item=N82E16817114174
Subtotal: $1,314.90
