$1400 build
This rig will be used mostly for gaming and I was wondering what you all thought of it. I would prefer to keep it single GPU and I already have a keyboard, monitor ETC...
http://pcpartpicker.com/p/hzhnXL
-LinuxForYou
Dropped the ram to 8GB (2x4GB DDR3-1866 CL9 1.5v dimms) and upped the GPU to GTX970 ... guarantee this to game much better.   $1405.87
http://pcpartpicker.com/p/cmyDnQ
Other than that  ... it is a rock solid build  ... best warranties on both the SSD and the hard drive ... solid mobo and CPU ...
the case is really big and you may consider the
Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ... quiet & good dust filtration & less expensive
https://pcpartpicker.com/part/fractal-design-case-fdcadefr4blw
