I need some headsets for about $140 preferably wireless due to the wires is a pain in the ass. I have seen the Corsair Vengeance 2100 but there's seem to be a slight problem with the audio with a hissing after some googling it. Are there any other options that kinda fit my budget.
ps. I live in Australia and the 2100 costs $139 at the lowest price
If you need a good wireless headset get the G930 I have and I love the dam thing.
Googled the 930's seems to be worse than the 2100 i try to bear the 2100 but thanks for the offer.
I have seen the g930s get mixed reviews but it seems like your best alternative. I immediately thought of them. I think Linus did a "series" of wireless headsets he reviewed. You might want to look around for those and let that help your decision.
I have seen Linus series of wireless headset and they were out of my budget.Still I used to own some Logitech headset of a similar design and my ears would get irritated even after an hour or two though it was pre-owned but I would suspect it would do the same to me if I actually bought it new.
