14.4 driver with pink screen
I am getting a pink screen when installing the latest 14.4 drivers from amd. i have reinstalled it many times and its still showing it as pink.
Please help me
Which 14.4 driver? WHQL or Beta?
Try to redownload the installer. Use DDU to uninstall in safe mode
http://www.guru3d.com/files_details/display_driver_uninstaller_download.html
WHQL
Try to redownload the file just in case and Use DDU in safe mode to uninstall. If you open DDU after you downloaded, it will ask you to go to safe mode and you just click ok/yes. Or you can manually go to safe mode and then use DDU.
The try to install the drivers.
I installed my 14.4 beta drivers without problems.
did exactly that and its still pink
got it changed it to rgb and back to normal now thanks
