so this is my first time building up a custom PC for myself, i am currently using a HP laptop for gaming and such, but i've decided to upgrade my computer, i want opinions on if the build will work with each other correctly, and if i can upgrade some parts for much cheaper.
Thermaltake Chaser MK-1 VN300M1W2N No PS Full Tower Case (Black)
http://www.amazon.com/dp/B0051U1XMI/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=3PW6B9FT8PBLQ&coliid=I7B71VC1KVCMB
WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX
http://www.amazon.com/dp/B0088PUEPK/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3PW6B9FT8PBLQ&coliid=I4FLONRFR7CWS
Corsair Vengeance Pro Series Red 8GB (2x4GB) DDR3 1866 MHZ (PC3 15000) Desktop Memory CMY8GX3M2A1866C9R
http://www.amazon.com/gp/product/B00D2LNLBY/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Corsair CX Series 750 Watt ATX/EPS Modular 80 PLUS Bronze ATX12V/EPS12V 744 Power Supply CX750M
http://www.amazon.com/dp/B00ALK3KEM/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3PW6B9FT8PBLQ&coliid=I2LVYFHVM1Z8HC
Arctic Silver 5 Thermal Compound 3.5 Grams
http://www.amazon.com/dp/B000OGX5AM/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3PW6B9FT8PBLQ&coliid=I2MHWA3H5JAOQN
Cooler Master Hyper 212 Plus - CPU Cooler with 4 Direct Contact Heat Pipes (RR-B10-212P-G?1)
http://www.amazon.com/dp/B002G1YPH0/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3PW6B9FT8PBLQ&coliid=I12VJCJRITP46P
MSI Computer Corp. Motherboard ATX DDR3 1333 LGA 1150 Motherboards Z87-G45 GAMING
http://www.amazon.com/dp/B00D12OBEU/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=3PW6B9FT8PBLQ&coliid=I1EFA90BWRRHUY
EVGA GeForce GTX760 w/EVGA ACX Cooler 2GB GDDR5 256bit, Dual-Link DVI-I, DVI-D, HDMI,DP, SLI Ready Graphics Card (02G-P4-2763-K?R) Graphics Cards 02G-P4-2763-KR
http://www.amazon.com/dp/B00DHW4HS4/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3PW6B9FT8PBLQ&coliid=I2ZICMHJHCID7M
Intel Core i7-4770K Quad-Core Desktop Processor 3.5 GHZ 8 MB Cache BX80646I74770K
http://www.amazon.com/dp/B00CO8TBQ0/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3PW6B9FT8PBLQ&coliid=I2NAQ2OHVOJMFT
SanDisk Extreme SSD 120 GB SATA 6.0 Gb-s2.5-Inch Solid State Drive SDSSDX-120G-G25
http://www.amazon.com/gp/product/B006EKJCWM/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A2UPZ5KC4AAZJ2
