$1300 Build, is there anything I should change?
Hey guys, what do you think of this build I was thinking of? I know that I could probably get a better CPU, but I like to support AMD. (Nothing against Intel)
Link to the build:
http://pcpartpicker.com/p/qrUS
looks great but if you know how to overclock then get the fx 8320 becuse you could easly over clock it to be the same speed as the fx 8350 but other than that i looks fine maybe a bigger psu for future upgrades but it will do for what you have now
depending on what you are doing for editing you should go Nvidia 16gb ram if not go
get 8 gigs of ram also do you really need 256 gb of ssd?
if not go with a 128 and put more money into your graphics
