13.8 Beta problem
I have no idea if this is the correct place to post this but I put it here because it is the problem is with a graphics driver and I couldn't find a drivers thread.
So I was installing the 13.8 amd drivers and my screen turned off, I thought, oh that happens some times right? No my screen then turned on and off, when it was on it was still just a blank screen. Sometimes it would stay on for a while say 2-5mins and sometimes when it did this I could move the mouse and the curser would appear. I eventually gave up a and held in the power button until it shutdown. I booted up and still the screen would flash. So I finally opened windows 8 boot manager and went to advanced repair options and ran a system restore on one I created before installing the driver, I usually do this as I have had driver issues on another pc and this has now become a god habit of mine.
I am using a dell inspiron 5520 with and i3 3110m, 7670m and 6gb ram running win8 64-bit.
I am running the latest amd drivers before 13.8.
Also to add in when I was installing the driver which was the mobility one, I had no applications running in the background like chrome, also I had my bluetooth mouse unplugged, it had caused problems before.
I am wondering if anyone has the same problem as me and if they managed to find a fix for this.
Any help would be much appreciated!
13.8 is a very experimental driver that solves microstuttering for crossfire. That doesn't mean that its normal that the drivers fails so hard, but it does mean that your 7670m has got absolutely nothing to gain with the driver at all.
I would recommend Stay at a older version until there is a newer beta update. I'm doing the same because the beta hates eyefinity.
And system restorepoint? That's a little overkill. Next time try
http://sites.amd.com/us/game/downloads/Pages/catalyst-uninstall-utility.aspx in safe mode or so.
