so my CPU heatsink (hyper 212 evo) has come down with a case of the coil whines. it needs a new fan badly. functions fine, but that noise...ARGH
basically, i was looking for fan recommendations for a 120mm PWM silence optimized fan that ISN'T a noctua...
the noctuas are amazing i'm sure, but the cpu cooler is smack dab in the middle of my case window, and i really hate how those fans look....
looking for something all black or black and white, something to roughly match my Define R4
thanks guys, i know i can just search for fans on Newegg, but i wanna know what's ACTUALLY reliable and quiet and decent for a CPU cooler.
Coil whine is caused by electromagnetic coils, something not present in a heat sink.
corsair sp120 quiet edition (allmost as good as a noctua)
Corsair SP120 Silent Edition
SP120 aren't just as good as Noctua's. That's rubbish!
They're a bit louder and the build quality and customer support isn't even on the same planet.
If you wan't premium, well built fans that are near silent and still perform very well.
Fans that have all the accessories you could ever dream of and the best customer support to back them up,
you get Noctua NF-F12's. Because there is only one to rule them all.
-EDIT: Also, Noctua is coming with all black fans soon. Most likely a black version of the NF-F12 too.
fan girl much?
http://www.youtube.com/watch?v=11TIfocssvY
Allso i run NF-F12's on my rad there is around a 1c difference between them at 12v's
well, regardless if it's coil whine or not, it's annoying :P and loud, it's not the heatsink it's the fan on the heatsink.
Is that corsair fan PWM? or doesn't that matter? that just means it will run on full blast all the time right?
The corsair SP 120 Quiet Edition fan's are 4 PIN PWM.
I run Thermalright X-Silent 120MM. They are dead silent on max. Also have some from Be Quiet I like.
I second bequiet! all of that European build quality just like Noctua without the hideous color palette.
If you are still in the market for new fans these Cougars are amazing http://www.newegg.com/Product/Product.aspx?Item=N82E16835553002 and you probably wont find anything for a better price than these right now.
i went ahead and ordered those corsairs last night, i got the silent pwm models, i intend to put both of them on my heatsink and run them as slow as possible for ULTRA SILENCE.
or ya know, something like that
