1200€ pc
I completed my build now and want your opinion. Maybe I can save some money.
  • http://pcpartpicker.com/p/BIiE
  • and 2 parts I couldn't find there
  • CPU-Cooler:   Thermalright HR-02 Macho http://www.thermalright.com/products/?act=data&id=178&cat_id=27 35€
  • Powersupply: be quiet! Staight Power E9 CM 680W http://www.bequiet.com/de/powersupply/276 129,90€
All for 1200€
I will use it to play games and do some Videoeditting and coding
What do you say?
I have the same motherboard and the 2500k not the 3570k. Personally, I wouldnt go for te 660ti. Not got the best price to performance ratio in terms of graphics out there. I'd get a 670 if you want to use CUDA for video editing, but go AMD if you dont. AMD seem to have some great value cards out right now. I don't have any experience with your CPU cooler, but it looks beefy enough to get you to 4.5GHz if you want to overclock. The motherboard will take you there no problem.
Yeah I was thinking about the same problem :/ Thought about the 7950 or 7970. They cost nearly the same as the 660ti.
go for the 7970. Epic card.
Costs 350€. Same as the 670. Hmm. I will watch endless benchmarks :D Thanks
