http://au.pcpartpicker.com/user/Spiral350/saved/1xN7
Comments?
lookin good, do it
Those extended plastic shrouds on the 660tis and 670's really annoy me, I'd swap it for an aftermarket like msi or galaxy BUT that's just me
I'd personally use the NZXT Vulcan over the Corsair 350D. Corsair cases seem to bit a bit overpriced, and their fans aren't exactly quiet. The Vulcan is about $50 cheaper, and it has a nice carrying handle for portability, which is what I expect you to want from a micro-ATX case :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146065
build looks good champ.
The Vulcan is a lovely case. The only problem is that it doesn't have front panel USB 3.0.
The Corsair 350D looks bloody amazing. Dual 140mms in the front, dual 120mms in the top... That case is a beast. I'd gladly pay the $129 price-tag, but I'm going for a bigger case, the CM Storm Stryker.
Looks good. But are you sure you don't need more storage?
