http://pcpartpicker.com/p/MBBV
do u think i should change anything?
Im going to be using it for rendering , gaming , and video editing with sony vegas ( which likes open CL better than cuda so dont tell me to get nvidia. )
I would change the CPU cooler. I have the performer, and I have to say, I don't like it.
Looks good, but I'd ditch those sickleflow fans, if you read reviews on them they don't put out nearly the performance they claim. You might also want to drop your ram down to 1600, you'll notice a greater improvment in the tighter timings than the speed. Also if you can go for XFX or Sapphire for Radeon cards, they really make the best and XFX has a lifetime warranty.
http://pcpartpicker.com/p/MHc4 the thing i did was get the h100 and got better fans.
then i got 8gb of ram instead of 16gb because i can just get more in the future
