I’m having issues with this brand new network card I just bought from my proxmox server. I also just got the server, it’s a Dell R420 and the network card is a trend net TEG-10GECSFP(v2), which is just an aquantia NIC according to their driver that I downloaded and compiled on the proxmox host.
The issue is that I can see the NIC in proxmox and I assigned it to it’s own bridge(vmbr1) however I cannot get my container(owncloud) to be able to communicate from this bridge, it cannot even get a DHCP lease.
Here is the networking config for proxmox
auto lo
iface lo inet loopback
iface eno2 inet manual
iface enp8s0 inet manual
mtu 9000
iface eno1 inet manual
auto vmbr0
iface vmbr0 inet static
address 192.168.10.222/24
gateway 192.168.10.1
bridge-ports eno2
bridge-stp off
bridge-fd 0
#mgmt 1gig nic build into mobo
auto vmbr1
iface vmbr1 inet manual
bridge-ports enp8s0
bridge-stp off
bridge-fd 0
bridge-vlan-aware yes
bridge-vids 2-4094
mtu 9000
#10gig tp link aquantia nic
I am able to tcpdump from the proxmox host and see arp traffic and LLDP traffic but it seems like the driver for the 10gb nic is not working at it should.
According to my research the nic driver was allegedly in the kernel already but that did not work at all until I compiled it.
Here’s the into from ethtool for the driver.
driver: atlantic
version: 5.4.103-1-pve-kern
firmware-version: 3.1.77
expansion-rom-version:
bus-info: 0000:08:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
Any help is appreciated! I was also considering just PCI passthru for this nic but I know that will just punt the driver issue to the guest OS so I’m not sure that’s more helpful. The point of this NIC is mostly just for whatever guest os/container I can get up and running for a “NAS”, since my switch has sfp+ 10gb I really wanted to take advantage of that throughput.
Thanks for the reply, I was having some other issues with proxmox and this is a new server so I wanted to ensure all hardware was working correctly. So I nuked the proxmox install and went straight ubuntu 20.04 LTS server. Everything is working great except this darn NIC. I even got a new sfp+ cable to ensure that it wasn’t a bad cable.
Here’s the interface info:
2: enp8s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc mq state UP group default qlen 1000
link/ether 3c:8c:f8:f9:8f:86 brd ff:ff:ff:ff:ff:ff
inet 192.168.10.221/24 brd 192.168.10.255 scope global noprefixroute enp8s0
valid_lft forever preferred_lft forever
inet6 fe80::5e8a:6a72:f23a:41b5/64 scope link noprefixroute
I’m using the built-in driver, info here:
driver: atlantic
version: 5.8.0-44-generic
supports-test: no
supports-priv-flags: yes
Dmseg is providing the following output:
[514156.089588] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514163.889106] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514189.869840] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514195.848942] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514213.969115] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514215.008929] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514215.469676] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514222.635414] device-mapper: table: 253:0: linear: Device lookup failed
[514222.635419] device-mapper: ioctl: error adding target to table
[514222.824109] device-mapper: table: 253:0: linear: Device lookup failed
[514222.824113] device-mapper: ioctl: error adding target to table
[514223.445117] device-mapper: table: 253:0: linear: Device lookup failed
[514223.445121] device-mapper: ioctl: error adding target to table
[514223.686749] device-mapper: table: 253:0: linear: Device lookup failed
[514223.686753] device-mapper: ioctl: error adding target to table
[514230.808931] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514268.489501] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514269.008786] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514316.188816] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514316.448685] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514318.009378] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514319.308681] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514328.688701] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514332.848595] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514335.849508] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514341.308692] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514351.468951] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514359.268592] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514411.448473] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514418.988438] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514419.469162] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514419.988425] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514426.928589] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514428.748390] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514544.428753] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514551.188078] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514588.268760] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514588.527965] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
[514588.828205] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 10000 new 0
[514590.907972] atlantic 0000:08:00.0 enp8s0: atlantic: link change old 0 new 10000
