I’ve been rocking a Dual Display (DP1.4) + 4PC Level1Techs KVM for a few years now. And while overall it has been an amazing tool, it has not been without it’s issues (which I go into more detail with below).
However I recently picked up a Single Display + 2PC 10G model for another project, and the issues I’ve had with my setup have completely vanished when dropping this device in. Issues completely unrelated to the USB3 5Gbps / 10 Gbps links back to the host.
TLDR: If you’re trying to decide between the 5Gbps and 10Gbps models of the KVM, it might be worth picking up the 10Gbps even if you don’t actually need that extra bandwidth.
Now to wait for the 4PC variants of the 10Gbps KVMs to become available …
DP Troubles
Driving a display at the absolute limits of what DP1.4 can handle is super iffy. I use a AW3821DW, which is capable of 3840x1600@144Hz@8bit (and no DSC support). But I’ve never been able to run that display through the KVM at those limits. I’ve had to stay at or below 120Hz@10bit. If I attempt any higher, I’ll have snow artifacts or consistent screen flickering.
And even at the reduced refresh rate, it’s not perfect. I’ll frequently have the flickering/artifacts after switching inputs, and have to juggle the inputs a few times until it’s stable. Switching to FIBER DP cable (from PC to KVM, and KVM to Display) does dramatically reduce the likelihood of these issues, but even that does not let me drive the monitor at it’s full capabilities.
Additionally, even at the reduced refresh rate, I have to be selective about the input ports. PC1 and PC2 will not work without serious flickering/artifacts at anything above 100Hz. Also have an issue where the display on those inputs simple will not get any input during POST and boot, until after the OS has loaded. Even if I get my system to boot directly into UEFI menu, I’ll get not display output. Makes tweaking bios super annoying…
Last year I picked up a Single Display (DP1.4) + 2PC KVM (5G model) for my spouse’s setup. Works perfectly fine for her setup, but I tested it with mine and had to exact same issues noted above.
Doesn’t seem likely that I have a faulty unit. That said, I did run into another user on reddit that had same exact DP issues with a Level1Techs KVM and the AW3821DW. He was able to return the AW3821DW and picked up the LG38" display that uses the same panel, and that works for him without issue. So maybe the issue is with some Dell funkiness.
USB HID Troubles
For the most part USB HID devices through the KVM has been completely fine, other than some expected and documented issues. I’ve been using the G502 Lighspeed for years without issue. I’ve seen some reports of users having issues with Logitech’s device that use the lightspeed wireless protocol, but it’s worked great for me through the KVM.
However back in September I picked up the new G502 X Plus mouse, and that’s a different story. When connect through a HID port, the device will stop responding either after an indeterminate period of time, or after I switch inputs. The only way to restore connectivity is to either unplug/replug the dongle, or run Logitech’s ‘Onboard Memory Manager’ utility, which seems to wake it back up.
This is easly worked around by just using the USB3 ports for the mouse. This complicates my setup through, as I liked to keep these ports ‘stuck’ to a particular PC and not follow the selected input.
