Hey guys. I'm really confused about getting my new PC. I have no clue which parts to take. I have a preliminary build http://img824.imageshack.us/img824/7283/ams1.png but I'm confused about it. I want to optimize it a bit and put R9 280x in it. maybe replacing Intel with AMD could be a good idea... My computer will be used for streaming and playing some games. ability to record gameplay would be amazing too. do you guys have any ideas?
ps. I've checked the other threads but no one was using R9 280x in their build. why? is it not worth buying? Mantle support would be nice too :p
what about streaming and gaming in general. would I get the same performance with fx 8350 and 990fx as I would get with my i5 that is in the build atm?
btw I only care about streaming and gaming. I dont care about 3d or video rendering
i5s are better core to core, but as a whole the fx 8350 stomps it. I went from a 8350 to an i7 4770k and i can feel the difference, the 8350 is much snappier with programs and is right up there for gaming with out mantel.
After researching for a couple of hours I've decided to go with AMD. now the only thing I need is motherboard to go along with my processor :) Could you guys help me with it? is it possible to get a nice motherboard for 100-150$? could you point me to an exact model? I also need RAM to go along with that motherboard and my new CPU. I have no clue what works well with AMD CPUs since I've always been an Intel fanboy, but I think it is time to wonder into AMD world.
I've looked into saber tooth, but I live in Europe and here the price difference is much bigger, so I can't really afford it now. :/ (In my country saber tooth would cost a bit more than 250$) :) I could order my parts in US, but then I would face shipping fees and some troubles with warranty so it would cost the same as if I would buy it locally. at my price range I'm looking into something like this http://www.skytech.lt/970ag46-msi-970ag46-970-dualddr31866-6xsata3-raid-gblan-atx-p-108997.html#tabsnav-1
But there are so many models for the same price and it is so hard to tell the difference in which one is better. btw at least some overclocking possibilities would be nice.
BTW! PSU? what should I get? I was thinking about 650W psu with intel. But I have heard that AMD is using more energy. I've tried using online PSU calculators and It gave me ~850W can it be correct? this number seems to be a bit too high imo :)
I will be running R9 280x and AMD FX 8350 with sabertooth. 1TB WD black hard drive and an SSD from my laptop that I'm not planning to use anymore (120 GB kingston)
Ok guys thank you so much :) I will make sure to stick around on this forum because I was not expecting to get such good responses. I am very grateful I will make sure to come back to you guys if I will need any more tips :P
